what type of oil do u use
Falken-18c
Post by Falken-18c »
yea just seeing what other ppl use for oil for when i do my oil change never changed it in my ss but will when i get it up and running i use quaker 10w30 in my 92 legacy na every 4000-5000km but not planning on using it in the 22t and i just used fram oil filters also how many litre of oil does the 22t take
x2hawt4ux
Re: what type of oil do u use
Post by x2hawt4ux »
i use royal purple oil and filters
92 turbo legacy: RWD W58 SWAP, td04, 3"tbe, mbc, fmic, wrx brakes/hubs, wrx seats, welded 4.11, fcd, drift steering wheel, Drifting Stickers
hitzkrieg
Post by hitzkrieg »
I use 10w30 castrol syntec and a Subaru oil filter when I change the oil in my TW. The oil capacity is 4L for the turbo engine. You should also change the crush washer on the drain plug every time you change the oil. Avoid Fram filters, they're cheap for a reason. If you're going to use an aftermarket oil filter, Purolator filters are probably the best to use.
- 94 Touring Wagon, Quicksilver Metallic 95k miles
Rubasu
Post by Rubasu »
I use royal purple for all my fluids! I use royal purple filters when available if not i use WIX filters.
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
LookAsubie
Post by LookAsubie »
Castrol Syntec 10w-30 and Fram filter. Every ~3k
1992 legacy SS 5mt, Winestone Metallic.
volny
Post by volny »
LookAsubie wrote:Castrol Syntec 10w-30 and Fram filter. Every ~3k
same here, and last bought high mileage chevron oil, seems to work fine. My ride leaks oil so I get to experiment with all brands hehe.
I have a friend that use to have an oil leaking car back in the days that ran forever since the oil was always clean :D lol...
coffeeman885
Post by coffeeman885 »
Castrol 10w-30 (dead dinosaur type) and Purolator filter. I usually like to change my oil after a race so like once a month. Always worked well for me.
( I change it every 3k in the off months)
Speed limits are like herpes - once you get them you will never be rid of them. - Jeremy Clarkson
'94 Legacy L Wagon "Bluella"
Mobil1 10w30.
valvoline 10-30 fully synthetic & mobile 1 filter
Mobil clean oil 5000 - 10w30 (dino oil)
SWRT
Post by SWRT »
I use whatever brand's on sale with a filter included.
Before when I had an engine with bad bearings I used 20w-50 and now I just stick with 10w-40.
The 20w-50 kept that engine running for the 37k miles I put on it with the main bearing going. Wix filters
are some of the best, but they're hard to find here. Royal Purple's like $8 a quart here. I'm going with
Eneos Fully Synthetic 10w-30 now though since my neighbor can get me oil changes for $30.
lucas
Post by lucas »
why the knock on fram filters? that rubber grip they put on it is awesome.... i use castrol and fram forever.
1993 legacy ss "Shela"
Royal purple is a retarded waste of money.
Falken-18c
kimokalihi wrote:Royal purple is a retarded waste of money.
i was thinking that.. when i change my oil im probly just gunna go with mobil are castrol 10w30 dunno about which filter probly stick with fram idk i never had a problem with them
SWRT
Post by SWRT »
Castrol's not a great oil. Mobil is probably your best bet for the cheaper oils.
Fram's ok if you get the better quality. The Purolators suck if you get the regular,
but the PureOne is good.
lucas
Post by lucas »
quakerstate
Falken-18c
i used quacker state in my na never had a problem thats cheap oil lol it gos on sale like every 2 months like 10$ 4L are 5L cant rember but thats cheap i seen this oil called certified its probly like bulk oil idk its alway 10$ 5litre
Baddog
Post by Baddog »
Explain? I got some and my car *Feels* smoother. I was going to try Amsoil next. I redline the car a lot and will be using it for the track shortly (auto-x)
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
Rubasu
Post by Rubasu »
I thought this post was for people to let others know what they use, not bash on what others use. Everybody has their own opinion on what they like and use in their car.
IronMonkeyL255
Post by IronMonkeyL255 »
Legacy777 wrote:Mobil clean oil 5000 - 10w30 (dino oil)
+1, and Purolator oil filters.
Rio Red '91 Legacy SS
SWRT
Post by SWRT »
I'd put Amsoil in every time if I could ever find the stuff here.
Falken-18c
amsoil is all over here i was thinking about using it but idk i might just use mobil1 i got time til i get my engine in my car and do an oil change
SWRT
Post by SWRT »
I used Amsoil for my diffs. It was $30, but should last the life of the car.
lucas
Post by lucas »
can someone actually tell me chemically why one oil is better than the other, not just based on price and personal preference
Falken-18c
i cant tell u chemically but i know that quaker oil gets black fast and some people says it leaves sludge but i still used it i think mainly just change your oil on a reguler basis my father uses mobil1 and after 5000km and it doesnt seem to be as black as quaker state im probly gunna use castrol are mobil1 but if i do use quaker in my ss motor ill change my oil sooner
