impreza_GC8
Post by impreza_GC8 »
magicmike wrote:
impreza_GC8 wrote:Diagnosed a bad injector and now I have to park the car while I try to find a set of JDM sidefeed 440cc injectors. I'm thinking about just using stock EJ22T injectors. I'm only running 11psi of boost out of a VF8, but I don't know if the stock injectors can handle that.
I thought the stock fuel system was good for 16 psi? Someone correct me if I'm wrong.
That would be nice if so. I am using a 2.5L block though, not 2.2, in case that would have any affect on fueling.
BSOD2600
Post by BSOD2600 »
* Removed the TMIC
* Installed a new knock sensor
* Removed the clutch master cylinder.
* Installed the clutch repair kit.
* Reinstalled cylinder
* Replaced slave cylinder... oh wait, the damn starter is in the way of the bolts.
* Remove starter
* Replace slave cylinder
* Reinstall starter
* Reconnect line and attempt to bleed clutch system, Curse at the slack in the pedal travel at the top.
* Reinstall TMIC
* Fiddle around with the adjustment screw on the master cyliner, which nicely tightens up the pedal play. yay!
Weekend cost: $136.56
'11 WRX Limited
'94 TW | R.I.P.
HappyFrog
Post by HappyFrog »
Cleaned IAC (again), let it idle a bit, reved it a couple of times, had a short chat with the neighbour, "yes it's subaru, yes it's a bit loud, no it wasn't built in hell", went back indoor now smiling.
Deride
Post by Deride »
Drove over a rabbit, not the car but the critter... Also yelled at the moonroof for leaking on my head like usual.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
N1446
Post by N1446 »
installed side marker lights , installed foglight switch , installed normal-style radio antenna
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
Post by SubaruNation »
made it mo' black and pur in the walbro 255 :-D
Imprezive
Post by Imprezive »
flogged it good 'n plenty :D
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
magicmike
Post by magicmike »
mashed the butt end of my maglight into the starter so it would kick over...
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Imprezive
Post by Imprezive »
magicmike wrote:mashed the butt end of my maglight into the starter so it would kick over...
Dude! I've got a piece of wire with two alligator clips on either end if you want it!!
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Where's the fun in that? I once kicked over a GL using the spare tire hold down. Convenient that they put it over the transmission.
Put it in the garage and swapped stuff.. :(
speedmaxx
Post by speedmaxx »
I went out side and found my kyb gr2's and my h&r springs at my front door step!
SWEEET!
should have them on by this week end
93 legacy l
to much to list....
Post by entirelyturbo »
There are four right rear quarter panels for 90-91 sedans left in the country.
On Monday, I ordered one of them.
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
brand
Post by brand »
You can fit an EJ22 in the trunk of a sedan.
91 SS with a bunch of parts waiting on the shelf
94 SS with things and such
08 STI with stuff and junk
Might even get the tranny in there with it.
:D
SubiePrice88
Post by SubiePrice88 »
installed SimplySubie fender braces...
But it sucks because the car doesnt run yet
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
Logged about an hour's worth of time on the Link driving around town. Also installed wiring for the toggle switch to turn on/off the ECU logging.
biggreen96
Post by biggreen96 »
Lol I keep my lug wrench under my seat just for that reason! Happens about every 3 days.
I fixed the rear drivers side window, now it goes up and down! I have had the car for 5 years now and it was just one wire I had to repair.
LostinMaine
Post by LostinMaine »
I did some more body work on the SS welded in some new metal at the right rear quarter and then put body filler on that and both rockers. Also discovered that my excessive shifter movement is due to blown bushings in the u-joint of the mechanism and i think my return spring is off too
Co Founder of MaineSubies.com
91 SS, in need of some major TLC (work in progress)
Im lost in Maine, but ill find my way out eventually
roundeye
Post by roundeye »
Put in a new knock sensor the Subaru gods sent my way today. Can't believe the old one didn't set a code with the crack it had, but tested @542k. Pulls harder already!
DerFahrer wrote:There are four right rear quarter panels for 90-91 sedans left in the country.
And here it is...
Dent-free as well! Amazing despite the condition/age of the box and the imbecile delivery driver who practically tossed it off the truck unloading it.
LostinMaine
so jealous!
fngearhead
Post by fngearhead »
Painted the summer wheels satin black last week. Autocrossed it on Sat then it got the clay bar and wax this week. The Jeep gets to play tomorrow.
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
HappyFrog
Post by HappyFrog »
Removed the air filter and realised it was the cause of my boost problem :lol:
Apex3
Post by Apex3 »
Washed it, then got new connectors so I could hook up my train horn switch correctly, then briefly considered hooking up my 4 channel amp to my speakers instead of the subs, but realized I didn't have speaker wire.
