That would be nice if so. I am using a 2.5L block though, not 2.2, in case that would have any affect on fueling.magicmike wrote:I thought the stock fuel system was good for 16 psi? Someone correct me if I'm wrong.impreza_GC8 wrote:Diagnosed a bad injector and now I have to park the car while I try to find a set of JDM sidefeed 440cc injectors. I'm thinking about just using stock EJ22T injectors. I'm only running 11psi of boost out of a VF8, but I don't know if the stock injectors can handle that.
* Removed the TMIC
* Installed a new knock sensor
* Removed the clutch master cylinder.
* Installed the clutch repair kit.
* Reinstalled cylinder
* Replaced slave cylinder... oh wait, the damn starter is in the way of the bolts.
* Remove starter
* Replace slave cylinder
* Reinstall starter
* Reconnect line and attempt to bleed clutch system, Curse at the slack in the pedal travel at the top.
* Reinstall TMIC
* Fiddle around with the adjustment screw on the master cyliner, which nicely tightens up the pedal play. yay!
Weekend cost: $136.56
* Remove starter
* Reinstall starter
* Reinstall TMIC
'11 WRX Limited
'94 TW | R.I.P.
installed side marker lights , installed foglight switch , installed normal-style radio antenna
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
mashed the butt end of my maglight into the starter so it would kick over...
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Dude! I've got a piece of wire with two alligator clips on either end if you want it!!magicmike wrote:mashed the butt end of my maglight into the starter so it would kick over...
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Where's the fun in that? I once kicked over a GL using the spare tire hold down. Convenient that they put it over the transmission.
- quasi-mod-o
There are four right rear quarter panels for 90-91 sedans left in the country.
On Monday, I ordered one of them.
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
Might even get the tranny in there with it.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Logged about an hour's worth of time on the Link driving around town. Also installed wiring for the toggle switch to turn on/off the ECU logging.
Lol I keep my lug wrench under my seat just for that reason! Happens about every 3 days.magicmike wrote:mashed the butt end of my maglight into the starter so it would kick over...
I fixed the rear drivers side window, now it goes up and down! I have had the car for 5 years now and it was just one wire I had to repair.
I did some more body work on the SS welded in some new metal at the right rear quarter and then put body filler on that and both rockers. Also discovered that my excessive shifter movement is due to blown bushings in the u-joint of the mechanism and i think my return spring is off too
Co Founder of MaineSubies.com
91 SS, in need of some major TLC (work in progress)
Im lost in Maine, but ill find my way out eventually
- quasi-mod-o
And here it is...DerFahrer wrote:There are four right rear quarter panels for 90-91 sedans left in the country.
![Image](http://i40.photobucket.com/albums/e244/fahrer4184/QuarterPanel.jpg)
Dent-free as well! Amazing despite the condition/age of the box and the imbecile delivery driver who practically tossed it off the truck unloading it.
